EPROM Programmer
EPROM programmers are used to program erasable programmable read-only memory (EPROM). EPROMs are a non-volatile memory type which once programmed, retain data for ten to twenty years and can be read an unlimited number of times. EPROMs can be erased by shining an intense ultraviolet light through a window that is incorporated into the device and re-used. Dataman EPROM programmers support a wide range of the most popular devices in use today - with devices being added monthly. EPROM support includes NMOS/CMOS, 2708, 27xxx and 27Cxxx series, with 8/16 bit data width and full support for LV series. All Dataman EPROM programmers come with a 30 day money back guarantee, comprehensive warranty and life-time technical support.
  Dataman S6 Compact USB Programmer
USB powered universal 48-pin chip programmer with compact dimensions and minimal weight. The S6 can program without the need for a family-specific module, giving you the freedom to choose the optimal device for your design...
Dataman 48Pro2C Super Fast Universal ISP Programmer
Super fast universal 48-pin programmer with ISP capabilities and USB 2.0 connectivity. The 48Pro2C is built to meet the demands of development labs and field engineers for super fast universal chip programming...
  Dataman 48Pro4C Super Fast Universal ISP Programmer
Super fast PC universal 48-pin programmer with ISP capabilities and USB 2.0 connectivity. The 48Pro4C is built to meet the demands of development labs and field engineers for cost effective universal chip programming...
  Dataman 48Pro2 Super Fast Universal ISP Programmer
Super fast universal 48-pin programmer with ISP capabilities and USB 2.0 / parallel connectivity. The 48Pro2 is built to meet the demands of development labs and field engineers for super fast universal chip programming...
  Dataman 48Pro4 Super Fast Universal ISP Programmer
Super fast universal 48-pin programmer with ISP capabilities and USB 2.0 connectivity. The 48Pro4 is built to meet the demands of development labs and field engineers for advanced universal chip programming...
  Dataman 48Pro2AP Super Fast Industrial Universal Programmer
Super fast industrial universal programmer with ISP capabilities and USB 2.0 connectivity. The 48Pro2AP is built to meet the demands of production programming with automated handlers and ATE machines...
Dataman 448Pro2 Super Fast Gang ISP Production Programmer
Super fast universal ISP gang programmer with four independent 48-pin ZIF sockets and USB 2.0 connectivity. Concurrent programming options combine with device insertion tests and a user friendly interface to give higher programming yields and reduced failure rates...
Dataman 448Pro2AP Super Fast Industrial Gang Programmer
Super fast industrial gang programmer with four independent modules, ISP capabilities and USB 2.0 connectivity. The 448Pro2AP is built to meet the demands of high volume production programming with automated handlers and ATE machines...
