| Signals on the S4 ZIF32 socket | ||
Signal Name SCLK DATAIN DATAOUT SELECT GND VCC |
S4 ZIF32 Name /OE /CE+D7 D0 A16 GND VCC |
S4 ZIF32 Pin number 24 22+21 13 2 16 32 |
| Wiring (SPI 25Cxx family – top of the ZIF24) | |||||
ZIF24 Pin 1 2 3 4 |
SPI Pin name CS SO WP GND |
S4 ZIF32 Signal name SELECT DATAOUT VCC GND |
ZIF24 Pin 24 23 22 21 |
SPI Pin name VCC HOLD SCK SI |
S4 ZIF32 Signal name VCC VCC SCLK DATAIN |
| Wiring (Microwire 93Cxx family – middle of the ZIF24) | |||||
ZIF24 Pin 5 6 7 8 |
Microwire Pin name CS SCLK DIN DOUT |
S4 ZIF32 Signal name SELECT SCLK DATAIN DATAOUT |
ZIF24 Pin 20 19 18 17 |
Microwire Pin name VCC nc nc GND |
S4 ZIF32 Signal name VCC VCC GND |
| Wiring (I2C 24Cxx family – bottom of the ZIF24) | |||||
ZIF24 Pin 9 10 11 12 |
I2C Pin name A0 A1 A2 GND |
S4 ZIF32 Signal name GND GND GND GND |
ZIF24 Pin 16 15 14 13 |
I2C Pin name VCC WP SCL SDA |
S4 ZIF32 Signal name VCC GND SCLK DATAIN |
| Connections | |||
ZIF24 Pin number 1 2 3 4 5 6 7 8 9 10 11 12 |
S4 ZIF32 Pin number 2 13 32 16 2 24 21, 22 13 16 16 16 16 |
ZIF24 Pin number 24 23 22 21 20 19 18 17 16 15 14 13 |
S4 ZIF32 Pin number 32 32 24 21, 22 32 32 16 32 16 24 21, 22 |
| SCLK - serial clock used to generate clock signal for devices DATAIN - Data input DATAOUT - Data output SELECT - Chip select for 93cxx and 25cxx devices GND - Ground VCC - Supply voltage |
