Dataman Adapter Selection Guide
Which Programmers Does This Guide Apply To?
This guide applies to the Dataman 48Pro2C, 48Pro2, 48Pro2AP, 448Pro2, 448Pro2AP and 848Pro2 programmers. In addition, this guide applies to the Dataman 40Pro, 48Pro, 48Pro+, 448Pro, 448Pro+, 448Pro2AP-AU, 848Pro, MEMPro, PIKPro and T51Pro programmers.
Which Adapter Do I Need?
Based upon your device you will be looking at an adapter in one of four categories. A general purpose adapter, a device specific adapter, a BGA adapter or a module. Below I will describe how to select the correct general purpose adapter, device specific adapter or module for your device.
General Purpose Adapters, Device Specific Adapters and Modules
All the information required to select the correct general purpose adapter, device specific adapter or module can be found in the control program for the programmer. This can be done without the programmer connected but make sure to select "DEMO" when prompted.
Open the control program, click "Select" and enter the part number of the device you would like to program into the "Search" box. When you have found the device you would like to program, click on it once so it is highlighted. Click the "Device info" button and a new window will open displaying further details about the device. The "Common information" tab shows the programmers which support the device and which adapter is required. If no adapter is shown or the device is to be programmed through the ISP connector, then no adapter is required.
In the case that no adapter is listed or it is not clear which adapter is required or if you would simply like confirmation of the correct adapter then please submit a Technical Support Request and our support team will respond within 24h.
