Quick start guide for programming from a master device, from a data file and saving to a data file using the Dataman 48Pro2 super fast universal ISP programmer.
- Install the master into the ZIF socket, lower justified.
 - Click “DEVICE” on the menu bar.
 - Click “Select EPROM/Flash by ID”.
 - Read the message, if displayed and click “Yes”.
 - If more that one device has the same ID, select your device from the list.
 - Click the “Read” icon. (Wait until done), Note the checksum.
 - Remove the master.
 - Insert the blank EPROM.
 - Select the blank EPROM if is different from the master EPROM.
 - Click the “Program” icon.
 - A program dialog box is displayed. Click “Yes” to select the default values. (Wait until done)
 - Click the “Verify” icon. (Wait until done)
 - The programmed EPROM is now ready to use.
- Click the “Load” icon
 - Browse to the correct directory.
 - Select the correct file type.
 - Select the correct file.
 - Click Open.
- Click the “Save” icon
 - Select the correct path for the file.
 - Enter the file name.
 - Select the file format.
 - Click “Save” and the file transferred to the hard drive.
