Quick start guide for programming from a master device, from a data file and saving to a data file using the Dataman 48Pro programmer.
- Install the master into the ZIF socket, lower justified.
- Click “DEVICE” on the menu bar.
- Click “Select EPROM/Flash by ID”.
- Read the message, if displayed and click “Yes”.
- If more that one device has the same ID, select your device from the list.
- Click the “Read” icon. (Wait until done), Note the checksum.
- Remove the master.
- Insert the blank EPROM.
- Select the blank EPROM if is different from the master EPROM.
- Click the “Program” icon.
- A program dialog box is displayed. Click “Yes” to select the default values. (Wait until done)
- Click the “Verify” icon. (Wait until done)
- The programmed EPROM is now ready to use.
- Click the “Load” icon
- Browse to the correct directory.
- Select the correct file type.
- Select the correct file.
- Click Open.
- Click the “Save” icon
- Select the correct path for the file.
- Enter the file name.
- Select the file format.
- Click “Save” and the file transferred to the hard drive.
